Absolute newbie with request for info
Coolerman
Mar 2007
Lexington,KY
Good day mates, please forgive my newness!
I am an electronic tech that works in the process control sector of the asphalt and aggregate industries. I have recently been 'promoted' to learning PLC programming and was given an Idec Smart Relay to become familiar with the concepts. (Later they plan to purchase a full PLC for me to learn on. )
The Smart Relay is super simple to program. Took me about an hour to get it doing some simple things once I read the manual that came with it. However the documentation leaves uhhh... a bit to be desired? :) It does not cover programming concepts or how to use this function to duplicate that circuit type stuff.
Is there an on line forum or site that may have more detailed explanations for some of this devices functions? I have been reading a lot here but to be frank it's mostly over my head!
Thanks!
Have you gone through the "Learn PLC's" information on this site? The link is at the top of the page.
Hello. An absolute encoder on a rotary axis gives values in range -2147483648 to 2147483648. When value is > 2147483648 , the encoder value is...
20
2,350
I have 2 Absolute Encoders 8192 steps per Rev. (Model TR Electronic CEV65m-11003) These Encoders communicate to the PLC5-60 via Parallel push/pull...
1,551
Hello, First thank for all the help i've gotten through this forum over the years reading others threads. I'm having an issue with Kinetix 5700...
6,005
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,195
Hi guys I am new to Encoders, so I have limited understanding of how to actually configure it, to the situation that I am in. Using this Absolute...
1,620
