Allen Bradley WALLCLOCKTIME Compare
Paul,
The Tag you have created contains all the data you need. If your tag is DATETIME, then
DATETIME[0] = Year
DATETIME[1] = Month 1-12
DATETIME[2] = Day 1-31
DATETIME[3] = hour 0-23
DATETIME[4] = Minute 0-59
DATETIME[5] = Second 0-59
DATETIME[6] = Microseconds 0-999,999
So if you want to trigger something at 23:59:59 you will need to use 3 compares together.
Hope This Helps
Mark
I suggest to open the Sample Folder of your RS5000 ( C:\RSLogix 5000\Projects\Samples\ENU\v19\Rockwell Automation ) and select the following .ACD file:
Add_On_Instructions_Samples.ACD
It contains many useful Add On Instructions to import inside your application.
There are many examples about calculations over the Date and Time, that makes things easier.
You may use as per your request the one named "T_EQU"...
Another way to access Sample files is through the RSLogix 5000 Start Page - Open Sample Project
Hope this helps,
- [FONT=comic sans ms,sans-serif]fuzzy logic[/FONT]
Mark, I have downloaded the Logix5000 Clock Update Tool & assume this updates the system WALLCLOCKTIME in the PLC. Can I compare WALLCLOCKTIME[4] to a minute value of '4' using some sort of campare function?RegardsPaul.
Mark,
I am confused here. I wish to compare the current minute value in the PLC (which I thought would be WALLCLOCKTIME[4] with a fixed value of '59'. Where is 'DateTime' declared and does it get the PLC's current Date & Time values?
Regards
Paul.
Paul,
The tag DateTime is the tag which is created in the instruction GSV.
I have attached a copy of what I have done in the past. I am only moving the values for use elsewhere but you could use the tag DateTime, and not bother moving it to DateTimeInt.
The example shows Year 1998, the month as 10, the date as 3 and the hour as 21.
Mark
Mark,
I have a controller tag called 'PLC_Time' of type DINT[7] to store date time data. I use a GSV instruction (see image) to try & write the WALLCLOCKTIME year value to PLC_Time[0] year element but the value is always 0 instead of 2011 Any idea's what I am doing wrong?
Paul.
Paul,
Have you used the Logix5000 clock update tool to synchronise the clock on your PC with the one in the PLC.
You will need to add the device, browse to it and update the time.
Mark
Mark,
I have used the clock updating tool & the clocks are in sync. I just wanted a way of getting to the current PLC time but as I can't find a way to get to it I will use an event in RSView32 to achieve an event just before midnight.
Thanks for the help.
Paul.
Hi how's it going. Was just wondering if someone could help me out. Recently one of the guys over on the LinuxCNC forums put me onto getting an...
229
Hello, Does anyone have one of these cables and willing to open the case so I can see the cable connections inside? 2707-NC5 I have sourced the...
84
Currently trying to find: micrologix ethernet interface 1761-NET-ENI AIC to micrologix 761-CBL-AM00 Ser C cable These are used for micrologix...
133
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
173
459
