joanthegreat
im only starting learning plc... its just been a week that my class started... my prof gave this assignment. can someone help me answer this.. im using this logosoft simulator..and ive never used that simulator, just now. anyone who uses that simulator pls. make the diagram of this problem and post the file,,,if that is possible.. it will be a real big help.
here is the situation.
a motor is to be started using a start push button and stop using a separate button.three lapms will be used to monitor the status of the motor. a thermal overload relay is also added tp provide motor protection.
maybe for those who knows alot about plc this is just an easy question... hope you can help me.
thanks!!!!
thanks!!!!
