Berra Member B Join Date Mar 2007 Location Sweden Posts 137 Sep 28, 2010 #1 Hi Anyone who can explain why i get this error 8F24H Area error reading a parameter. when i am using FC50 Regards Berra
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,698 Sep 28, 2010 #2 Is your DB 20 bytes long ? I've seen problems with other Siemens blocks where poor coding results in a read access to a byte immediately after the data you are processing. If your DB is longer than 20 bytes you would never see the problem.
Berra Member OP B Join Date Mar 2007 Location Sweden Posts 137 Sep 28, 2010 #3 i get the same error, with my new db who is 40 bytes long ???
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,698 Sep 28, 2010 #4 Where is FC50 from - can you post a library with it in ?
Berra Member OP B Join Date Mar 2007 Location Sweden Posts 137 Sep 28, 2010 #5 L D[AR2 said: Where is FC50 from - can you post a library with it in ? Click to expand... look in the attachment
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,698 Sep 28, 2010 #6 FC50 is from the CP400 library - did you mean to use this ?
Berra Member OP B Join Date Mar 2007 Location Sweden Posts 137 Sep 28, 2010 #7 Yes, or can´t i do that???
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,698 Sep 28, 2010 #8 The library blocks for CP communication are for CP343, CP443 etc. There must some other blocks for dealing with CPU's that have on board Ethernet.
Berra Member OP B Join Date Mar 2007 Location Sweden Posts 137 Sep 28, 2010 #9 Ok. So my problem was that i used wrong communication blocks??
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,698 Sep 28, 2010 #10 Yes, the error code you are seeing is reported back from SFC58
Berra Member OP B Join Date Mar 2007 Location Sweden Posts 137 Sep 28, 2010 #11 OK, thanks , i have solved the problem i use sfb14 & sfb15 instead.
