gbradley
MY PLC has only discreet inputs cards currently.
Thermocouple Input card for CompactLogix is $1500 bucks and I am not sure if it is even available.
I had a click laying around with Thermocouple input
We have successfully connected the Click to the same RED Lion HMI
The Click thermocouple output (C0-04THM) is connected to a Temperature Tag on the HMI, so I can now display the actual temperature on the HMI.
I want to make it so that if the temperature is above a certain value, (150°F ) then the Compactlogix knows that the temperature has reached 150°F and it will kick it out of Automatic Mode and flash a warning.
I understand that I can modify the click code to turn on an output if the temperature reaches a certain value. We can run the Output from the Click to an Input on the CompactLogix.
Is there a way to do the same thing using a rung in the CompactLogix using the Temperature Tag in the HMI?
