Hi, how do I find out if my input or output work or not.
I have a switch probe and a indicator light. I'm using omron zen v3 to program. I check my connection continuity and voltage manually, it works fine, light turns on when I use a wire to connect my in and out. my mean question is how do i see the input turn 0 to 1 and output turn 0 to 1 in the plc. I can't seem to see in the plc when I running the software plus it doesn't turn light on. input I1, output q1. same in the plc.
any input will greatly appreciate. thanks.
