Cimplicity HMI & SQL table
sapoleon
Aug 2003
salta, salta
315
I have seen, how easy is to make a data table with Cimplicity HMI, and SQL. Just say if you want a data log or an event log, and its everything nice and selfmade practically. Just add the point to the table.
But, I am now in a situation that I can not use that. I have a specific table in a SQL server, and I have to add my point to that table, and even the name of the columns, is not the name of my points. That would be the first part of my problem, the question is, does someone knows how to do that? I am trying in the way of the SQLExecQuery, but I didn't managed to make it work.
The second part of the problem, is for the Trending, lets say I have already the points in this outside table, how can i use them with the trends? or i should have also a Cimplicity table (duplicated) just for the trends?
from now, thanks.
Ok, the first part of the question is solved already. It seams I was tipping something wrong. The script looks something like this now:
Dim s As String 'this is used temprarily to check results
Dim qry As Long
id&=SQLOpen("dsn=K22;UID=sa;PWD=****",s)
qry = SQLExecQuery(id&,"INSERT IGNORE INTO T_Data (Counter, Run_No) values (1, 'deriv')")
qry = SQLExecQuery(id&,"UPDATE T_Data SET Counter = 0 WHERE Counter = 1")
id& = SQLClose(id&)
there are more INSERT and UPDATE items, (40 of them) but the idea is the same. and i put them also in if conditions, that are not relevant now.
But still, I can't get it to work with the trends. I don't get the table available, to choose the points from it (when using expression logged).
every advice will be appreciated.
thanks again
I didn't get how to use the external table in the trending. so far, I used the intrinsic trend data of the points, for 30 days, (I think its enogh), for the graphics, and the sql for saving the points to use with an external SPC.
The problem is somehow my CIMPLICITY SQL server disappeared from my service manager and i can't even find it in administrative tools/services... i...
2,986
Hi, I am developing project in Cimplicity 9.0 and I want to communicate it with PLC on S90_TRIPLEX protocol. Also want to communicate with...
2,346
I have a question related to the tag definition of a Cimplicity HMI tag. I have an existing application in which I have csv export of the tag DB...
2,052
Hi Members! Can anybody give an useable link where can I download GE-Fanuc CIMPLICITY HMI v6.0 software? I would like to install this software...
2,960
Hello everyone, I'm learning to program the Cimplicity HMI 8.2 recently. Do you have any suggestions where can I find some helpful manuals or...
8,855
