cabbie27 Member OP C Join Date Jan 2017 Location hamilton Posts 6 Jan 24, 2017 #16 Data type is a string as that's what the laser sends. Digi One is programmed for an ascii import
mobsoft Member M Join Date Jun 2013 Location Bowling Green, KY USA Posts 43 Jan 24, 2017 #17 What happens if you use 1 as your destination node? I use Digi One's a lot with numerous products.
daba Lifetime Supporting Member D Join Date Jul 2004 Location uk Posts 5,401 Jan 24, 2017 #18 Now you've confused me.... Your configuration picture showed your message type as "SLC Typed Read", and you were reading N60:4. So what is exactly the scenario ???
cabbie27 Member OP C Join Date Jan 2017 Location hamilton Posts 6 Jan 25, 2017 #19 Got it working: the path and config were setup correctly. I made an error in one of my permissives to start. I appreciate the help with everything.
daba Lifetime Supporting Member D Join Date Jul 2004 Location uk Posts 5,401 Jan 25, 2017 #20 cabbie27 said: Got it working: the path and config were setup correctly. I made an error in one of my permissives to start. I appreciate the help with everything. Click to expand... Thanks for getting back - nice to know the path I gave was correct...
