ceilingwalker
Good day all. I have a SLC5/05 that is connected to a Red Lion HMI. They are connected via a network switch. This system has been working good for a couple of years but I have a new issue that has started within the past month that I can't figure out. There are actually two Red Lion HMIs in this work group with static IP's. The one HMI loses comm for up to a minute while the other does not. The distance from the switch to the HMI that is losing comm is less than 100 feet. Does anyone have an idea as to what may be causing this and a possible solution? Thank you much.
