Communicate on more than one subnet with CompactLogix
oldmanraskers
Sep 2014
United Kingdom
I need to connect one PLC to two subnets and use the MSG instruction across each subnet - I understand that I can't use the built in Ethernet port to send messages to both subnets because it's tied to one subnet address, but would I be able to realise my requirements if I add an extra ENBT card into the sub rack? Thanks in advance.
Yes.
We use this setup, where one ENBT/Built in ethernet port is used for local communication in the 192.168.x.x range.
And where a second ENBT is used to communicate to our plant network in the 10.x.x.x range.
Using MSG instructions on both networks.
Thanks for hitting me back Jeebs, I expected that to be okay but I didn't want to buy a card and find out it wasn't - looks like that won't be the case. Again, thanks :)
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
70
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
81
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
622
We have some very old technology in my plant that needs adjusted but I don’t have the equipment. Can anyone tell me what I need to program this IO...
391
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
246
