Communication between TP270 & S7-200 CPU226XM
chamo_plc
Feb 2005
Hi there.
I’m new in communication between HMI Siemens and PLC Simatic S7-200.
I need to communicate a CPU 226XM with a HMI TP270 and I don’t know how to do this.
May anybody help me please?.
I need MPI cable pin-out too.
Thanks a lot for your help.
Chamo PLC
Chamo,
trata este link:
http://www2.automation.siemens.com/simatic/portal/html_76/techdoku.htm
Navegar Siemens website no es facil (hay que tener bastante paciencia)pero se consigue cualquier manual que necesites ... pienso que puedes conseguir information acerca del cable pin-out y cualquier otra detalle de configuracion de hardware (tal vez software).
Desafortunadamente no tengo ninguna experincia con S7-200 family (diseñado en USA) ... yo uso S7-300 y S7-400 que son diseñados en Europa y son bastante differentes.
Buena suerte,
LJAM
You can use this simple cable, it's good for lower bitrates:
CPU TP
3--------------3
8--------------8
CPU port is 9600 bps default set
from ProTool create your new project, select
protocol: SIMATIC S7 - 200
parameters..network parameters: profile Standard, bitrate 9600
Hi guys!.
LJAM, tu español es mejor que mi ingles jeje.
Gracias pot el link pero ya busque en Siemens y solo obtuve informacion para hacer lo que me recomienda RGUA.
RGUA, past friday I connected both ports using pins 3 and 8 (RS-485 port) but I doesn't works.
I used 19.200 because MPI protocol works from it baud rate.
I believe that I have a problem with PORT1 of CPU226 configuration, I use register SMB130 for this but I'm sure that there is some problem with it.
In the Protool side I believe that I have a configuration problem too with Area Pointers, I'm not sure about its configuration.
Do you have some idea about that?.
BR
Chamo
Hi
Leave SMB130 at 0. It's for freeport communication only. Set up your comms parameters in the 'System Block' in MicroWin, make sure they match in the TP and use 3-3 and 8-8 cable.
pp
As paraffin said you don't need work at SMs, configure port 1 by Microwin "Bloque de sistema" and download the program:
"carga CPU" --> opciones -->bloque de sistema
Read this application note:note_HMI_200
Area Pointer involves data exchange. Read the help in ProTool
THANKS!!!!!
Thanks Guys!!!, I got communication between PLC and TP, I just needed to configure SYSTEM BLOCK (thanks PP).
Well, all of you win a beer, if any of you comes to Venezuela contact me and I will pay you hehe.
I'm sure I will have more questions and I hope to be in touch with you!!.
Regards
Chamo
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
169
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
61
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
131
175
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
157
