Abn said:
...I just want to use the controller without I/O modules...
OK, so you don't need to inhibit anything in this case.
The 1769-ECR end cap is definitely only required for the relevant CompactLogix controllers if there are local 1769 I/O modules present. The same may be said for the MicroLogix 1500 without any local 1769 I/O modules - no end cap is required. The controller may be used on its own. However, in a running system, it would of course not be advisable to install just a controller without the end cap(s). At the least they keep out dust and prevent inadvertent contact or shorting of the socket pins.
Also, if you wanted to just use this controller on the bench for testing, but at a certain firmware revision that is not currently flashed to the controller, say go from r17 to r20, then you would need the 1769-ECR end cap fitted to perform the firmware flash.
Hopefully that is not the case here? But either way, I would definitely be purchasing a "relatively" inexpensive end cap as opposed to attempting to replicate an end cap with resistors or loops. But, then again, where is the fun in that and when needs must?
I do recall a thread here some time ago with some member attempting this?...I'll have a look see...
1769-ECR... are they required??
Ah, very good Ken, you had dissected the end cap circuit and LoganB was going to try it (sacrifice!) his test controller. We didn't really reach a conclusion though, pity?
Any more volunteers!?!
I have a few 1769-L31 controllers in the stores that will never be used here again. I could try wire one to blow, but I just don't have the spare time at the moment.
p.s. I can get a 1769-ECR here from Radionics for €26.52 - not bad. Although I do just get them through the distributor with the controller, etc.
Oh, just checked a recent quote and good discount -
1 EA 1769-ECR CompactLogix Right End Cap €21.80 EA -8.00%
€20.06
G.
