Lemming
This thread astounds me.... I have never come across a motor of any size without a terminal block....
I see nothing wrong with wire nuts if the conductors are small, like up to AWG.8. And always be sure to tape the connections well after nutting. Larger connections I would use a split bolt, followed by a layer of vinyl tape, a layer of rubber splice tape then another layer of vinyl. If done properly you will never have an issue.
My experience has been just the opposite. Only on the smallest fractional HP motors have I ever seen a TB inside the peckerhead.
As far as how to make the connections, this may turn into an "old school" vs "young buck" type of thing. The tried and true method is ring tongue terminals bolted together. Then taped with any of many variations of tape. Very dependable but time consuming. The Polaris style connectors seem like the new "best" way tome.
It is a code violation to tape wirenuts. The NEC takes the position that if a wire-nutted connection "needs" tape, either the nut is installed improperly or a nut is inappropriate for the splice.
Split bolts are tough to beat. The first layer of tape should be applied sticky side OUT. That way, when the tape must be removed, a simple slice with a knife allows the tape to be easily pulled away from the connector.
I think it is a US thing.This thread astounds me.... I have never come across a motor of any size without a terminal block....
The proper tape isn't to provide isolation, but as an add-on to keep the wire-nut there in case of loose connections in house installation. If the tape is used for something else, it's improper installation.
We have tried Polaris connectors with no luck, they would strip out or vibrate loss or because they were aluminum they would work loose. We have had very good success with split bolts, glass tape would sticky side out , rubber tape then vinyl tape. takes a while to connect but does not fail.
I have seen many mateThis thread astounds me.... I have never come across a motor of any size without a terminal block....
