ContolLogix5000 & GSE 663 Scale
SCTbird92
Mar 2005
I am trying to communicate with the Scale via Ethernet.
Has anyone done this before? Looking for some help.
TIA
Morgan
I've used the Devicenet module mutliple times with great success for the GSE Scales. Is the Ethernet option on the GSE Ethernet/IP or TCP/IP?
Ethernet/IP.
I can "see" the Scale on RSNetworx.
I can get to the GSE Web Server in the Scale.
I downloaded the .txt file from GSE to set up the Ethernet Option.
I wanna point a Tag to the Registers I need through RSLogix5000.
TIA
Morgan
By "see" do you mean you have the correct EDS file for Ethernet/IP. I had to contact GSE directly to have them e-mail me their .eds file for their deivcenet card option. They do have a technote page on their website and tech support is decent but you have to find the right person. I'm afraid I can't help you out any further then this point.
TIA
Morgan
Does this scale support AB Ethernet I/P?
I have been confused by this before, just because a device has Ethernet, does not mean it will show up in Contrologix in the I/O tree.
LJBMatt said:
Curly. He replied above that the option card comm is Ethernet/IP which is what AB uses.
When you look at the specs on the GSE 663, it supports Ethernet with no mention of Ethernet I/P, only Modbus TCP/IP.
Unless this is a new card that has not made it to the literature
yet
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
82
Hi all, I have a GSE 465 scale connected to a ControlLogix 5561 plc via an ethernet module. The scale, plc and HMI were working fine. Without...
4,650
Could any one help me out with config. My dl 06 com. port 2 to read from a scale that has rs232 comm also. The scale is a GSE 60 Series. I have...
4,452
