CPU 313c-2DP connect with CANview Profibus
Maira
Oct 2007
madrid
Hello,
my english is not very good and i do not have experience in PLC´s.But i need to connect a CPU 313c-2dp with the slave CanView Profibus.
I have de GSD files in the step 7 but i do not know how to configure de Can View Profibus....
Does anybody any experience ??
thanks a lot...
Dont know the "CanView" you mention.
This is a general description how to add an external profibus device via the GSD file:
Open the HW Config.
Use the function Options .. Install GSD file.. to import the GSD file into the HW Catalog.
Select the port on the CPU that is to be used for the Profibus network. Set it to "networked".
Select the Profibus network that is attached to the port. When selected the line that resembles the Profibus network changes to solid black.
Then find the desired Profibus component in the HW Catalog. There will be an entry under Additional Field Devices. When you doubleclick on the desired component it will be attached to the selected Profibus network. You will be prompted for a station address. Change it or just accept the suggested address.
Depending on the type of component, you may then have to add further sub-components into the slave station. These typically represent i/o modules. If this is the case you have to study the documentation for the device in order to figure out which sub-components are necessary for your application.
Hello JesperMP
Thanks a lot for the reply.
We had external help to resolve the problem. The problem was the profibus wire. Now I have to buy one, and my question is: If there is a special cable for profibus DP.
Thanks a lot.
hello maira;
Here are documents showing the 2 Profibus-D{P cables we specify i n our projects:
This one from Siemens, we generally only require the standard cable:
This one from Belden:
Hope this helps,
Daniel Chartier
CPU 313c-2DP all LED got flashing. That time all output gets deactivated. After total power reset only it get's comes stop mode. Then its goes...
4,272
Hi all experts i want to know how i connect 2 CPU 313C-2DP one as master and the other one is slave i will make this connection to increase my...
2,159
hi I have a password protected cpu with mmc card.Is there any possibility to take the program from it via its ports or via mmc card. thanks
2,032
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
139
Hi guys, I have CPU S7-300-313C ( Cat No - 6ES7-313-5BE00-0AB0) DI24/DO16 and AI5/AO2. when I am trying to configure and use the AO channel PQW...
2,575
