Joel201
Hello,
I will be editing a program in a CJ1M CPU11 the problem is that my laptop doesn't have a serial connection so i bought a CS1W-CIF31 and CS1W-CN226 cables. I have already installed the drivers for the cables. Can anyone teach me the port settings that i should make in the device manager (eg. Baud rate, Parity, Data bits, Stop bits, and flow control) and in the CX-Programmer. I am have not done this before so i am quite new so do i use the toolbus in the network type?
Edit*
And if i were using those cables do i need to change some dip switches on the plc or does the cable converter has some dip switches too.
Thanks,
Joel
Edit*
Thanks,
Joel
