DB9 Bulkhead...
Eric Nelson
Apr 2002
Randolph, NJ
4,346
I'm looking to mount two DB9 male connectors on the bottom of an enclosure. 14 gauge, so it's a bit thick for a Greenlee punch. I don't need a cover on the connectors, so a Graceport is overkill. What I'm looking for is something similar to this:
http://store.haveinc.com/p-53319-avp-db9-female-crimp-socket-contacts-connector-kit.aspx
I'll probably end up buying these, or making my own bulkhead panel using port savers, but just wanted to know if there were other options. It would be nice if there was something that mounted in a round hole, like those RJ45 bulkhead connectors from Molex and others.
šŸ»
-Eric
Thanks, rpoet... :site:
L-com is usually my first stop (along with Winford) for stuff like this. I thought I had combed the L-com site, yet I didn't notice these... šŸ™ƒ
I have to built 5 identical panels, so I think these will be easier (for me) to install than the Switchcraft ones (and cheaper). I built a panel last year with a few XLR connectors (LINK), and I remember them being difficult (odd hole size or something).
Oh, and no need for a square hole... Two accurately positioned holes with a 1" knockout punch should suffice... ;)
šŸ»
-Eric
Eric, XLR connectors are a PITA to mount. You're right - the holes are a non-standard size. I use XLR connectors all the time for the automation gear I build for theater; I use Neutrik's DL-series connectors.
http://www.neutrik.us/en-us/xlr/dl-series/
I have mounting plates laser cut from 14ga steel with the connector holes I need, and then I mount that plate in a square/rectangular hole in the cabinet. Let me know if you'd like a CAD drawing for my Neutrik connector mounting plates. I'd be happy to email it to you.
Another huge bonus for me is that Neutrik makes an entire series of connectors that all fit the same knockouts. They have XLR connectors with 3-7 pins, a mains-voltage series of connectors called PowerCON, Ethernet passthroughs, and even Firewire and USB.
They also have an 8-pin connector called an NL-8 SpeakON that makes a GREAT rugged multipin connector. It's a bigger knockout than the DL series, but easy to have the holes laser cut.
I'll bet that the DB-9 Switchcraft connectors someone posted earlier in this thread fit the same holes. Switchcraft tends to copy Neutrik.
-rpoet
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,575
Hello guys, I am trying to control a ATV12 via Modbus Poll software. I need the connection diagram for Altivar Modbus RJ45 port to DB9 port. Thank you
577
Hello everyone, How important is it to obtain cable pinouts from a vendor whem connecting a device with DB9 connector to a device with DB25...
2,657
Could someone point me to a DB9F right angle cable that would allow me to close the door on a L61 PLC? Certainly one exists but all I can locate...
1,793
We have a cable with two male db9 sides. The connected pins are: 2 to 2 , 3 to 3 , 7 to 7 , 8 to 8 . What could be this cable type...
3,168
