diesel locomotive plc
stevedunk
Apr 2006
FNQ
52
hi
we have some light locomotives that are using modicon micros with a120 add on cards for engine , converter , instrumentation control.
not a real good choice for a dusty vibrating environment,
however they have worked ok for some years but as you would imagine
they are beginning to cause problems.
i am interested in finding a suitable hardened industrial plc,24vdc inputs, relay outputs with analogue i/o in a brick type.
Any suggestions?
Are you referring to the old modicon micros or the later modicon tsx micro with the telemecanique branding on?
Also need to know the io count to give a recommendation
old modicon micro they used 28 digital inputs 12 out and a couple of anolog in and out. it wasn't the best programming job and i would be seeking to minimise when i rewrite.
Hi, I am looking for a sensor to monitor the level of Diesel Fuel And Gasoline in an outdoor Storage tank. The Tank has cylindrical shape laying...
1,879
Hi. It turns out running just inverters off of a generator is bad for the generator. Any tips? Ideally I would like to size my diesel generator...
2,481
Hi Gents I am working on a fuel storage and dispensing facility. Initally the storage part was being done by others, and I have completed the...
3,447
Reaching out to all the seasoned folks, what would you use if you were to provide a 300 kW power generation system? A diesel genset or a...
17
6,225
Hi, I'm new here and I don't know is this topic belong here? I would like to know if somebody have experience in putting Beckhoff CANopen master...
3,017
