Distributing line tracking encoder pulses
cncsparky
Dec 2014
Ks
98
Hello everyone! First post, long time lurker.
We have a conveyor/paint system that has an odd way of distributing the line tracking encoder pulses(at least to me anyway :unsure: ).
The 'A' pulse from an encoder is fed into an input of a micrologix 1100 1763-L16BBB. Every 8 pulses it outputs a pulse which I'm assuming is per inch of travel. This output pulse is fed to the input of 3 separate micrologix 1400's running paint reciprocators in other panels spread out.
The outputs from the 1100 used are 0/0 and 0/1 which I believe are solid state outs. Yes, two 1400's are fed from output 0/0 and one from 0/1 :unsure: .
I get a nice clean raw signal from the encoder on my scope, but the output from the 1100 pulses are varying frequency and time period. We believe this is causing an issue with painting in the wrong areas of our product.
The output of the 1100 travels through shielded blue hose to the 1400's panels.
Is this an acceptable way of distributing the line tracking pulses?
varying frequencies? assuming the encoder is tracking the conveyors per inch of travel, depending on the encoder type if absolute or incremental (read manual), will have s resolution, through which you can use to get your frequency, usually if this is a tracking application you would probably have a shift register.
I would suggest to see if your double counting or better known as "debounce". Sometimes you can have chatter that can cause a double pulse when their should have been just one. You can do this simple test with a counter on the encoders input.
Captain Obvious here: If it works, sure. If it doesn't , no
eight pulses per inch seems kinda odd to me. As everyone who works with inches and feet knows, stuff like that doesn't lend itself very well to math...
seems to me jawolthuis is right ... you probably oughta know for sure what's going on ... maybe the pulses are for some other reason
The encoder is an incremental, 300 PPR Accu-coder. Not sure of the conveyor rate of travel, but it is fairly slow. The pulses on the output of the 1100 jump around alot, hard to get a trigger on them. Seems they should be more consistent. Also, their pulse width varies. This is in contrast to the input (encoder) signal which displays on the scope as a pulse train as expected.
Are you certain that the output of the 1100 is intended to be a rate divider of the encoder? You've seen this in ladder logic?
You would need to know the ratio of conveyor pulley revolutions to encoder revolutions and the conveyor pulley diameter to determine the pulse per inch
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
291
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
138
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
209
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
85
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
187
