Dosbox and pcis
pdacosta
Jun 2015
Canton,Ohio
Hello
i have finally got dosbox and pcis working properly and communicating with the slc. Dosbox did not like the usb to serial convertor i was using. Now the problem i'm having is finding the right path to the prrogam for the slc 150. I have the program located on c, in a folder named shredder. I can't seem to get pcis to find the file????
Any help please!!!
It has been several years ago, but there is a way to pick the path in PCIS. It might be that you have to literally type it in first. If I was sitting right in front of it, I would remember. Perhaps there was a menu option (funtion key) to set the path first, then you type it in...
Also, in DOSBOX settings (again, it has been many years) you might be able to set the default path that is used by the PCIS software. I seem to recall moving my PCIS files to a folder on the root of C:\ because I had to type in the path name each time I used PCIS. I only had to use it a handful of times though. Somewhere in a thread on this forum, I believe there has been placed a link to the PCIS manual, and/or the SLC100/150 manuals which may give more information.
Thanks for your reply, i finally figured out how to find it (sort of)!!
I wrote the program over in pcis,(only 20 rungs) and then saved to disk. After that whenever i read from disk all the other copies of the program and any others in pcis format also appeared. Will still look for a way to find the actual path and i will make sure the programs are on the root of c drive. Thanks again
Hello All, I am attempting to upload from a SLC 100. I know the controller is good because it is still in operation. I know the programming port...
3,441
There has been a little more confusion on how to do this so I wrote up a procedure that may help (see the PDF), I put it on my website so I can go...
10,326
CAN ANYONE HELP ME WITH DOSBOX SETUP? I HAVE DONE CONFIG BUT WHEN I START DOSBOX AND ENTER STINGS 1st-TYPE:MOUNT C C:\AB_PCIS--ENTER ALL OK...
1,644
Hey Everyone, Looking for some help with getting Logic Master to run on Windows 7 64 Bit, right now I have transferred the LM90 file from the XP...
9,042
Hello, I need to support B&R System 2003 and 2005 control systems which were programmed using B&R PG2000 software running in DOS environment. My...
9,993
