EasyBuilder Pro/Ignition/MQTT
Sep 2019
Fresno
Hello folks,
I am working on an HMI application in EasyBuilder Pro using the software with the Simulation mode as an MQTT Edge Gateway.
This simulation is communicating to a PLC which is then sending data over to the Scada software Ignition. I have successfully been able to Publish data points through the simulation to Ignition through the HMI but can not seem to write back to EasyBuilder Pro. Any thoughts?
So essentially a subscribing issue.
Thank you!
Make sure you are using the "Sparkplug B" MQTT protocol, if not - Then there will be several other steps involved to allow a Write Back.
Here's a screenshot. (Now I don't think every Weintek/Maple HMI has the capability of "Sparkplug B" MQTT 3.1.1)
But using this version and protocol it will work flawlessly. (As this is what I use for the oilfields)
I have EB Pro installed on windows 11, I can open an existing project and edit but when I got to parameters tab and open page I get the hourglass...
62
Hi, I would like to know if it is possible to modify the properties of an object via a macro? For example I have a value of 100, via conditions...
871
Hi, I'm an intern student engineer and I'm tasked with creating a HMI for a control system in EBPro. I need to make an object (motor) which has...
1,786
Hello everyone Im Newbie to Easybuilder and im designing and HMI application where I gotta display a warning message in a pop up window...
1,810
I am banging my head trying to get EB Pro to convert simple math expressions. Ex: 1 Pump conversion coming from a SCP instruction O0 1.1 value...
1,874
