Eb8000
roxusa
Nov 2008
NJ
994
I am new to Easy Builder 8000 although I have managed to write a few screens and put them into use (a lot cheaper than PV+)
Can anyone tell me how or if I can create a momentary illuminated PB that the light is controlled by a separate bit. I did this in PV+ and program it so any button hit (pertaining to the same function) on the machine,
the function latches and all the buttons for that function light up, any of them pressed while lit they will unlatch the function, I could make a separate indicator lamp but would like to conserve screen space.
Select the box "Read/Write use different addresses". The read address will control the light. Always make buttons momentary, and do latching inside PLC.
I don't see that option, I select object-button-set bit and dont see it in the set bit object propertied window, what am I doing wrong.
I need a multi state indicator to display based on a register value. I can create it and it works fine my problem is the only one with the most...
1,398
I found a post asking about RS500 and EB8000 in online simulate and am trying to do the same thing.The post said to shut down RS Linx so it would...
2,283
I have used the Numeric display once before on a MT8070iH and used a 16 bit unsigned integer N7 then added the decimal point in the Numeric Object...
1,899
I downloaded EB8000 for a Weinview Display MT8070iH5, I can successfully download the application but can not get it to communicate with the PLC I...
18
5,022
Hi everyone, I found an information on forum that it is possible to make communication between simulation in RsLogix500 Emulate and Online...
2,864
