FactoryTalk ViewSE Trend - current value in legend? (using HistorianSE)
scotthower
Mar 2012
Pennsylvania
29
I have several trends setup in ViewSE 8.1 using HistorianSE data - none will show the current value in the legend caption. The min/max show correctly (and I've got those linked to the Historian values) but there are always blanks in the 'value' column.
Also - is there a way to show the caption / description next to the values when one clicks on the trend graph? It would be easier than trying to match up the colors and values with the legend.
I've attached a .pdf screen capture to show what I'm asking.
Thanks!
I have the same problem with an RSView32 I just converted to FTView 8.0.
I finally gave up and turned off the legend and just put them on the screen blow the trend.
I have problem convert Alarm factorytalk view ME to Factorytalk view SE? Im try to do everything not success Pls Tell me to method to success...
2,187
We are having issues with our viewpoint server randomly crashing and only loading the error page if anything at all. It lives on 3 servers all of...
18
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
108
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
74
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
90
