Feed Forward Bais in PID MLX 1200
ggchavhan
Nov 2006
pune
135
Hi
I have MLX 1200 C, I have aproject for Three Element Drum Level Control, In PID instruction setup FFB is there, I could not exactly understand the term FFB (Feed Forward Bais). Can I put steam flow as FFB and automatically remote set point will be acted to CASCADE Loop? How it works? Please Help me
GAJANAN
Feed forward bias is a value that is added to the output in addition to the PID correction. It is intended to supply output that you know is needed without requiring that the PID produce that value. It tends to get you to setpoint more quickly.
Keith
you may want to consider a level sensor or proportional weight control.
pid loops are not fast acting from what i have learned in the past.
if this is a 55 gallon drum filling up in 10 seconds for example, the pid loop may be to slow.
regards,
james
regards,
james
That's not really true. You can have PIDs that update in milliseconds...We routine use PI control on instantaneous web tension control on a process moving 1000 ft/min.
But I want to know how its affects on CV? is ther any expression (formula) applied?.. or other logic
Hi I have MLX 1200 C, I have aproject for Three Element Drum Level Control, In PID instruction setup FFB is there, I could not exactly...
2,236
Hey All, I am working on the programming to maintain level and pressure in a 80 gallon surge tank. This tank feeds fillers that fill either 2.5...
1,548
I have a startup issue in need of a solution, the problem involves 3 valves on a evaporation system. The three valves are a evaporator feed water...
1,532
I do a lot of hot water set projects, which are simply a steam heat exchanger with a steam control valve that adjusts to a PID setpoint- the water...
1,793
Hi guys! It seems to me that PID loops with feed forward are underutilized. Maybe it's just me but I think almost every loop would work better...
2,730
