FT View SE Comm fail with PLC alarm
bdossantos
Mar 2018
California
67
I am looking to know how people have implemented communication failure routines with PLCs (Allen B) in their FT View applications. recently took over 3 plant applications that need to be consistent and the apps use different methods of checking. two used derived statements and 1 uses event. Made me think of asking how other people have done this. Thank you
I don't know if it's possible in FTView since i don't use it, but my normal approach for software talking to a PLC is to have the PLC increment a heartbeat, and the PLC monitors it.
A script then checks the PLC tag every second against a memory tag. If its different, copy PLC tag to memory tag. If its not different (i.e. value in PLC not updating) then I increment another memory tag SecondsSinceComms.
Once SecondsSinceComms > whatever you want for a comms fail delay, raise alarm.
Last night electricians replaced the panelview and now there is no comms between the panelview and the PLC. The processor is a 1747-L541 SLC 5/04...
904
Is there a way to get FactoryTalk View SE to open the Comm Port of the computer using VB Scripting? I am using Version 10 of FT View. OS is...
1,058
Is it posible to get FactoryTalk View SE to open the Comm port of the computer? I have a USB to Serial converter attached to my computer. I know...
902
I created a project in FT View Studio. The first thing I did was set up the comm at the end of the tree and added an numeric display programmed it...
1,435
I haven't messed with ControlNet or Panelview + in a long while so I appreciate someone give me some pointers. Trying to install a new PV+ on...
3,357
