FX3U ethernet com. problems
Feb 2009
Sandefjord
Hey, I've som problems with the PLC to communicate through a router or switch using an FX3UENET module. When I connect directly to my PC, it work out smooth. But communication through the switch causing an unstable communication. Pinging the PLC through the switch gives different results. Looking forward to some good advice! Thanks :)
FX3U - Ethernet module - Beiger 1151hmi I have these setup on a press which all worked fine. But since swapping the FXU3-80 for a smaller FXU3-48...
2,875
Dear all, I am using an FX3u PLC along with an FX3u-ENET-ADP card and the card is connected to a PC which runs kepServer 5.19 Is there a way for...
2,031
Hi, I am working on Mitsubishi PLC project.I am using two PLC below. PLC 1 - FX3U (Master) IP : 192.168.0.10 PLC 2 - FX3g (Slave) IP ...
4,701
Wonder if some1 can help me. Im busy with a project and using a FX3U plc with a FX3U-ENET-L ethernet controller connected to a Beijer E1071 HMI...
4,083
My setup is as follows: FX3U PLC with ENET module. IP address 192.168.100.201. Have a Melsoft connection set for connection 4. Router: LAN...
6,359
