Help with an MVI56 MNET module
theback40
Nov 2012
FL
Hey all, new user here.
I'll be on here and there, but this time I could use some help. I have an MVI56MNET Modbus module and ControlLogix processor (Logix 5572) in a 10-slot rack.
My question is, the user guide for the MNET card is real good at explaining how to configure it, so overall I just want to make sure I am doing this correctly. This is the first time I've used this particular module:
If I want to move a single boolean value to the card for "viewing" over Modbus, I can write it to this address (for example)
MNET.DATA.WriteData[10].0
Now, how do I know which Modbus address corresponds to this? I see that I can set a Register Start address, but am unsure how to proceed.
And to move an INT, I can MOV it to (for example)
MNET.DATA.WriteData[20]
but I'm wondering, since I have REAL numbers and don't see how to configure the card to accept this data type, is it gonna puke when I give it an INT or will it round it off for me? (I would think it would eliminate the decimal automatically).
Thanks all, I don't have the hardware in front of me to play with, otherwise I'd try and figure it out on my own. Any help is greatly appreciated!
I've adjusted the IP of the Panelview Plus as well as the DNS servers; the screen does not show up in the search when I go to the transfer utility...
103
Hi Everyone, I own a GE Versamax controller that I purchased for a class at Long Beach City College a couple of years ago. I lost the use of my...
148
I was wondering if anyone could help i am trying to use a SLC 500 with a 5/05 processor to set up an incremental encoder to a HSCE2 card? The card...
161
Hello, I am working with cimplicity workbench, I have made changes to the current project from this machine I am using in the past. However when...
50
Hello, doing switch from FBD to ST. First task is converting my old work. How do you sum variables? For example, Interlock1, interlocl2 and...
192
