Newtonj
Configuration: Base Unit is a MPC240 with various IO modules one being a CM202 canbus module that needs to communicate with the ME203/CN.
The problem is that the me203 will not find the DCF files no matter were I place them. The me203 boots to /pcc0 and I have placed the DCF files in the /APP, /APP/CAN, and at the root /pcc0. Since ME203 doesn't find the DCF files it autoconfigures as a Slave on node0. This would be fine but the solution center requires the nodes to be between 1 and 64. I need the me203 to be node1.
