How many 1786-BNCP Controlnet connectors?
dogleg43
Dec 2005
Indiana
520
Two Allen-Bradley 1786-TPR Controlnet T-taps can be connected together with a 1786-BNCP barrel connector, that's understood.
But is there a limitation on the number of these that can be connected together end-to-end as long as a teminating resistor is used on the first and last 1786-TPR T-tap?
I have a panel with (1) ControlLogix PLC chassis, (3) RIO chassis, and (3) Allen-Bradley (2) fiber-to-ControlNet repeater modules. Each has a 1786-TPR T-tap and I was thinking about just connecting the T-Taps together with a 1786-BNCP between each T-tap.
This would keep me from using ControlNet cable or 1786-TJPR jumper cables.
No problem there. To save even more space, if you need, use the "Y" taps. I have panels with 10 "Y" Taps close mounted together with nothing but BNC barrels (one row on bottom, one row on top, staggered).
Good Evening , We have a number of Powerflex 525 Drives . I took notice for years elsewhere and our plant , that our Powerflex 525 drive...
658
Good Afternoon, Just wondering , are many of you using SAP in your plants ? If so , is it difficult to learn ? Are there many training...
1,448
It better to have too many instead of not enough right?
26
2,930
Hi all- I have an application where: - I have a fixed system with a pre-determined, static, network (say, 192.168.2.0/24). - That system...
4,259
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,192
