How to connect a SLC5/03 to a PC via DH485 (RJ45)?
+1
shaydzmi said:
What prevents me from using the pins 1 & 2 ? Do they have 24V?
Nothing but what are you going to use it with?, if I remember right its Pin 3 that has 24vdc
The UIC is a converter and converts DH485 to RS232 so your PC can understand it, your PC does not talk DH485
Hello, I have one legacy system that I'm trying to troubleshoot - it's a SLC5/03 connected to an old Panelmate 1785. I can connect to the SLC...
1,451
Hi there, I'm wanting to connect a panelview 800 to an SLC5/03 the SLC is connected to an 1747-AIC which is run to another 1747-AIC. I'm trying...
1,560
Tried a straight through 9-pin RS-232 and a null model cable. No luck so far.
1,551
Looking for some help to understand memory mapping for a slc5/05 utilizing a 1746-sn module to (2 manifolds) numatics 2.2 manifold coupled via...
2,213
Hello , im trying to connect to a slc 04 using the rs232 port but for some reason when i auto configure want let me , says check cable or switch...
17
4,327
