How to connect this motor?
agarb
May 2006
USA
309
I have a 600 volt IEC motor and I am a bit uncertain about how to interpret the wiring diagram. Can somebody look at the attached images and help me determine how to properly connect this motor? The terminal box has 12 leads of which are strapped together in six sets of two. I marked up the terminal box photo with how I think it should be wired but would like another opinion. Thx!
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
351
I was asked to disconnect and later reconnect a motor but told the customer it would be 4 hours before I could get there as I was on a job. They...
2,010
480V. 40HP to 50HP pumps. PLC control. 24DC. Customer specified Fused Disconnects at each pump. We are opting to do Fused Disconnect (UL98) -...
3,174
While not a PLC question, I figured there are people here who will have an answer for this question. I have two situations: 460 VAC motor with a...
3,404
Hi, Everyone I am a beginner to PLC. I am currently working on a project to build a door cycle tester. Allen Bradley Micrologix 1100 is used to...
4,268
