iFix communication with the ABR driver
RichardsBay
Aug 2005
Durban
I hav an iFix system and a controllogix 5561 processor...Iam having trouble in getting the data into iFix from the PLC. I thought that the ABR driver was configured properly but i just get invalid station invalid for the datablock validation..I can ping this address tho'.
Please help
RichardsBay said:
Please help
You need RSLinx Professional for ABR.
Also, I had an issue in which I had set up a new PLC on our existing system, and when I would try to test the setup, I would get the invalid station message. After a couple of reboots ABR connected up and started working and has worked ever since. I never did figure out why.
You also have the choice of Intellution's IGS driver (Industrial Gateway Server), since you are using ControlLogix. Also, IGS does not require RSLinx. I have found Intellution's tech support to be very helpful, especially on the driver setup end of it.
Hi all Can any one tell me on how to communicate bristol control wave plc to ifix using opc drivers in ifix...pls...its in critical stage...
2,307
Hi guys, I've been mulling over and failing at this for a while now, and I'm just stumped. I'm much more familiar with the A-B family, Wonderware...
3,793
I dont know how to communicate between my plc ABB AC500 with SCADA Ifix 4.5 ? i need quick help thanks in advance
4,386
Hi, I have an iFix server using the IGS driver connected to a AB SLC500 via ethernet. The SLC is connected to one Micrologix1500 over ethernet...
6,332
All, I tried to connect communication between Emulator 5000 and iFix by using OPC Power tool but have some problems. - RSLogix 5000 v15.0, I can...
9,866
