IM151-8PN cpu and ethernet
Plc_User
Dec 2005
Belgium
317
We have a system with a S7-400 and a WinLC-pc.
The S7-400 has an ethernet cp. Both are communication on ethernet with SFB12 and SFB13.
Now we want to split up a part of the communication : we will add an IMP151-8PN cpu that will be connected to the WinLC-pc.
Can the IM151-8PN handle the same communication with SFB12-SFB13 as the S7-400 with cp? Can the WinLC read from more then on plc with the SFB13? (Only about 60 bytes are transfered by each.
When communication is active between IM158-8PN and WinLC, is it possible to connect online with S7 and download on one of the not used ports on the IM158-8PN?
Are there specific parameters to be set in the IM158-PN because the ports are Profinet and not Ethernet?
Thanks.
I believe yes. You can find out by trying to create an S7 connection between the S7-400 CPU and the IM151-8 in NetPro.
Just make several connections.
It is a 3-port switch. So yes.
Thanks.
not really.
In our final configuration we replaced the IM151-8 by a 315 profinet cpu. I cannot test this exact configuration in the office. When I look online in the 315 PN cpu I see no SFB12-13, also when I look online in module information - performance data, there is no SFB12-13. I suppose FB12-13 are based on SFB12-13, as the sfc's are inserted in the offline project when FB12-13 are inserted.
I inserted FB12 in the 315 and no error messaged are displayed. The only communication partner I can set up in the office is a CP343-1 Lean. I suppose the 343-1 Lean does not support FB12-13??
What communciation block should I use between the WinAC and the 315 PN?
Hi In one of our machine, there is Seimens PLC IM151-8 PN/Dp CPU. HMI is connected via Ethernet and other devices are connected via Profibus...
3,126
Hi guys, I have IM151-8 Siemens PLC, i want to connect it with Modbus and read/write on it using Modbus protocol. How can i do this? Do i need...
2,559
Hi All, I am building a Profibus network using a Mitsubishi QJ71PB92D Profibus Master Module. Current Setup: - 1- Profibus Master (Resistor On)...
2,642
We have these in our shuttles. The IP Address is stored on the SD card for the unit. We had a card go bad and I am trying to copy another card...
1,154
Hi all, i want to make a TCP connection to an "other station" in Simatic Manager to be able to send commands to an external device. I wanted to...
1,936
