Import/export CSV files in GX developer
DairyBoy
Jun 2007
UK
393
Hello All. I'm trying to minimise the pain involved in writing multiple identical (in structure) rungs in GX. I used the export function to create a csv (ok) and did a trial edit in Excel (ok) but when I used the import function I get the cryptic message "This file don't access. Conversion stopped". I started by importing to the open project that I took it from with the cursor on the LH margin, then a few other places, then created another project using the same cpu type, but always get the same message. Am I expecting too much? Thanks.
OK, I've cured the "Don't access" thing by closing the excel file before importing. However, no matter how I juggle the import settings that pop up next, the conversion always returns an error on every line up to line 100, at which point it gives up (me too). I have now tried exporting / importing without opening the file. Also tried as txt file. Always the same result.
Hi, Im wanting to know if its possible to export a recipe UDT into excel to allow manipulation of the recipe, and then to be able to import it...
3,693
Can anybody help me, How can I import/export CSV file in Wonderware Intouch. I have to set some default setpoint using excel.Control Logix PLC I...
7,421
Hi I'm trying to import and export datasets of a project in CSV files, using a USB key. The OP is Siemens MP277. The user must be able to export...
5,888
Hello, I have a problem with RSlogix5000 v.15.01.00: When i export tags via the CSV file, the file is full of "?" character in...
17,303
Hi, Import and export of project text is no problem. But how does it work if additional texts are added after I send a exported copy of the text...
891
