msolano Member M Join Date Aug 2009 Location El Carajo Posts 22 Oct 8, 2009 #1 how can i do an interface InTouch with PLCSim? i need to simulate a s7-300 program and i don't have a PLC real. somebody could tell me the steps to do it?? please someboy help me!!! Last edited: Oct 8, 2009
TurpoUrpo Lifetime Supporting Member T Join Date May 2008 Location Switzerland Posts 1,571 Oct 8, 2009 #2 Did you use search before posting.
msolano Member OP M Join Date Aug 2009 Location El Carajo Posts 22 Oct 8, 2009 #3 but nobody could do before, I thought maybe someone could do after...
TurpoUrpo Lifetime Supporting Member T Join Date May 2008 Location Switzerland Posts 1,571 Oct 9, 2009 #4 Maybe this will do the trick: http://sourceforge.net/projects/nettoplcsim/
msolano Member OP M Join Date Aug 2009 Location El Carajo Posts 22 Oct 9, 2009 #5 yes, i used it but it don't work at vista
Thomas_v2 Member T Join Date Apr 2009 Location Ger Posts 520 Oct 9, 2009 #6 msolano said: yes, i used it but it don't work at vista Click to expand... Could you describe the problem at vista? Do you get an error message? I've tested it only on Win2k and XP, maybe it needs only a little fix to run on vista.
SCADA_Dude Member S Join Date Feb 2008 Location California Posts 115 Oct 9, 2009 #7 If you use an OPC server, you could use a second Intouch node to modify OPC tags using scripting in Intouch (thereby simulating a PLC).
PLC Member P Join Date Sep 2002 Location NC Posts 311 Oct 9, 2009 #8 I'm pretty sure that there is an active x installed when PLCSIM is installed. Have you looked in to that?
