Interface (network) card WinCC-PC
Apr 2003
Belgium
434
Hi there,
I'm planning to connect a WinCC HMI to a S7-300 PLC with a CP 343-01 (ethernet). What kind of network card do I need in my PC?
Thanks in advance
Fritz
I do believe that you need a Siemens comms PC card, for industrial ethernet using a PCI slot you will need a CP1613 or if you are using a laptop with a PCMCIA slot then the number is CP1513. Siemens CP cards are numbered up as follows:
1st digit:- 1 = Industrial ethernet (ISO and TCP/IP)
5 = Profibus
2 = ASi bus
2nd digit:- 4 - ISA slot
5 - PCMCIA slot
6 - PCI slot
3rd and 4th digit:- 11 = dumb card requires Softnet
12, 13 and 14 = Intelligent cards.
Hope this is of assistance to you
Paul
Hello Fritz;
You can use a CP1613 as PLucas suggests, in which case you will need a S7-1613 software license; you can also choose a standard (3COM type) network card, which will require a Softnet-S7 license. Both these licenses allow S7 exchanges between the network card and the S7 partner (in this case WinCC). The Softnet solution is cheaper, but will interrupt the PC processor every time there is an exchange over the network: it can cause a slowdown of the processor. Remember WinCC is very hardware intensive; a slowdown will soon become evident. If you can live with this aspect, choose the Softnet solutioon. If the spplication is time-critical, go for the Hardnet card (CP1613).
Contact your local Siemens rep. to get the part numbers and cost of the CP1613 and the required licenses.
Hope this helps,
Daniel Chartier
I wasn't sure if that was the case Daniel, which is why I did not mention it in my reply to Fritz, Thanks for putting me straight on that.
Paul
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
914
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
231
Hey Everyone, I need to Interface Ignition SCADA ethernet network to an Allen Bradley SLC5/04 Serial RS232 DF1. Has anyone out there found a low...
1,008
hello every one , i need a manual that contain the command for request the current message in the printer i was trying to send the command from...
1,431
We have a AB PLC-5/40 hot back-up system with 1746 Remote I/O and would like to interface Cutler-Hammer Westinghouse IQ-1000 II, IQ Data Plus...
12,262
