corretion...
just to avoid confusion ...
shark's thread is ok but has to be corrected .....
for example if you have timer "t37" and "t38" and you want to reset them in one rung , or you can reset more than two timers as illustrated below :
LD I0.0
R T37 , 1
R T38 , 1
and so on .....
or you can simply do it like this :
LD I0.0
R T37 , 2
this will reset timer t37 and t38, if you have more than two timers for example t39 , t40..then instead of " 2 " use "4" this will reset timers from t37 ---> t40.
please take a note , the above illustration will work fine with siemens PLC's as i've tried it many times before ... i dont know about AB or other brands.
hope this help..
best regards.khalil.
