KealanOCarroll
Level Control System, PID Controller I'll see can I tune any better.
I can fit straight lines to those plots really easily obviously, but is there any quick way to clean up the data or am I better off just leaving it as is?
E&H HART Pressure transducer at the bottom of the tank, 1m length of signal wire going through a backup power supply switching unit, into the ADC and profibus to the s7-300 PLC. The data stays as noisy when I stop the inlet flow so it's not sloshing in the tank as I first thought.
Also, WinCC Flex is outputting date & time in the CSV files, I've formatted them as both time and date in excel but it's putting the labels in a zeros along the X axis of the plot, anyone know is there a trick to sorting this?
The fact that both DD/MM/YYYY and HH:MM:SS are in the same cells seems to be throwing Excel
