KepwareEx DataLogger -- Unable to query recordset No Reason given.
just_lionel
Nov 2004
Edenton, NC
323
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number)
I keep getting the following error on the DataLogger
I have recreated the table many times from scratch. With no luck. I finally got it running once with no issue. Then the computer restarted (dang Windows update) and stopped working again. I'm lost...and aggraved.
Yes, no problem with the connection.
Log for this one only come back with this:
-- Query logging
-- Driver name: MySQL ODBC 8.0 Driver Version: 08.00.0036
-- Timestamp: 240407 5:51:32
1712483492:select TABLE_SCHEMA as TABLE_CATALOG,TABLE_SCHEMA,TABLE_NAME,COLUMN_NAME,DATA_TYPE,COLUMN_TYPE as TYPE_NAME,IF(ISNULL(CHARACTER_MAXIMUM_LENGTH), CASE DATA_TYPE WHEN 'bit' THEN CAST((NUMERIC_PRECISION + 7) / 8 AS UNSIGNED) WHEN 'json' THEN 1073741823 ELSE NUMERIC_PRECISION END, CHARACTER_MAXIMUM_LENGTH) as COLUMN_SIZE,CASE DATA_TYPE WHEN 'json' THEN 4294967295 ELSE CHARACTER_OCTET_LENGTH END as BUFFER_LENGTH,NUMERIC_SCALE as DECIMAL_DIGITS,IF(ISNULL(NUMERIC_PRECISION), NULL, 10) as NUM_PREC_RADIX,IF(EXTRA LIKE '%auto_increment%', 'YES', IS_NULLABLE) as NULLABLE,COLUMN_COMMENT as REMARKS,IF(ISNULL(COLUMN_DEFAULT), 'NULL', IF(ISNULL(NUMERIC_PRECISION), CONCAT('\'', COLUMN_DEFAULT, '\''),COLUMN_DEFAULT)) as COLUMN_DEF,0 as SQL_DATA_TYPE,NULL as SQL_DATA_TYPE_SUB,CASE DATA_TYPE WHEN 'json' THEN 4294967295 ELSE CHARACTER_OCTET_LENGTH END as CHAR_OCTET_LENGTH,ORDINAL_POSITION,IF(EXTRA LIKE '%auto_increment%', 'YES', IS_NULLABLE) AS IS_NULLABLE,IF(DATA_TYPE like 'json', 4, MAXLEN) as CHAR_SIZE FROM information_schema.COLUMNS c LEFT JOIN information_schema.CHARACTER_SETS cs ON c.CHARACTER_SET_NAME = cs.CHARACTER_SET_NAME WHERE 1=1 AND c.TABLE_SCHEMA=DATABASE() AND c.TABLE_NAME LIKE ? ORDER BY ORDINAL_POSITION;
-- Query logging
1712483492:Using prepared statement;
1712483492:SELECT * FROM `sor_db` LIMIT 1;
1712483492:ssps has been executed;
1712483492:query has been executed;
1712483495:ROLLBACK;
-- Query logging
-- Timestamp: 240407 5:51:35
1712483495:select TABLE_SCHEMA as TABLE_CATALOG,TABLE_SCHEMA,TABLE_NAME,COLUMN_NAME,DATA_TYPE,COLUMN_TYPE as TYPE_NAME,IF(ISNULL(CHARACTER_MAXIMUM_LENGTH), CASE DATA_TYPE WHEN 'bit' THEN CAST((NUMERIC_PRECISION + 7) / 8 AS UNSIGNED) WHEN 'json' THEN 1073741823 ELSE NUMERIC_PRECISION END, CHARACTER_MAXIMUM_LENGTH) as COLUMN_SIZE,CASE DATA_TYPE WHEN 'json' THEN 4294967295 ELSE CHARACTER_OCTET_LENGTH END as BUFFER_LENGTH,NUMERIC_SCALE as DECIMAL_DIGITS,IF(ISNULL(NUMERIC_PRECISION), NULL, 10) as NUM_PREC_RADIX,IF(EXTRA LIKE '%auto_increment%', 'YES', IS_NULLABLE) as NULLABLE,COLUMN_COMMENT as REMARKS,IF(ISNULL(COLUMN_DEFAULT), 'NULL', IF(ISNULL(NUMERIC_PRECISION), CONCAT('\'', COLUMN_DEFAULT, '\''),COLUMN_DEFAULT)) as COLUMN_DEF,0 as SQL_DATA_TYPE,NULL as SQL_DATA_TYPE_SUB,CASE DATA_TYPE WHEN 'json' THEN 4294967295 ELSE CHARACTER_OCTET_LENGTH END as CHAR_OCTET_LENGTH,ORDINAL_POSITION,IF(EXTRA LIKE '%auto_increment%', 'YES', IS_NULLABLE) AS IS_NULLABLE,IF(DATA_TYPE like 'json', 4, MAXLEN) as CHAR_SIZE FROM information_schema.COLUMNS c LEFT JOIN information_schema.CHARACTER_SETS cs ON c.CHARACTER_SET_NAME = cs.CHARACTER_SET_NAME WHERE 1=1 AND c.TABLE_SCHEMA=DATABASE() AND c.TABLE_NAME LIKE ? ORDER BY ORDINAL_POSITION;
Hi All, I had a question regarding Kepware. I was able to pull in data from my PLC tags along with the tags coming from the third party OPC...
1,102
i followed instructions in https://www.kepware.com/getattachment/da3be813-6b30-461c-bca4-5c0a186fe3cf/citect.pdf and configured a device. I then...
1,816
Hi, I am struggling to resolve a problem with Kepware OPC server. I got to read some array elements from an Energymeter to my RSView. Normal tags...
7,634
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
107
Does anybody have experience with the data logging on a Kinco HMI? I'm currently trying to log some dumb data. I have already created the DB and...
1,097
