Labeling Wires - M12 4 pin wires
Timeismoney08
Jul 2012
United States
312
First thing, do you put labels on all your M12 cables?
Second thing, do you label each wire coming out of as flying leads to be used in the panel? Allot of times I assume people know which wire is what, but maybe I shouldn't run like that.
One last thing, do you document each wire to each pin for m12 connectors in your drawings?
Thanks for the help!
If you don’t label the individual wires then at least label the cable on the inside of the enclosure. Otherwise, troubleshooting would be a problem.
Same thing for the prints.
When I mark the cables I put 2 labels on them. One label gives the description (Entry Photoeye) and the other is the cable number, if one, that is on the schematic.
Also, like Keithkyll I don't label the power and ground leads - just the others that are used. If one of the leads (pink or white) sets the operating status of the sensor by connecting it to either power or ground then I label it.
Mark the cable only. The wires are "labelled" by their color encoding.
You may chose to label each wire if you intend to be able to remove wires and reinsert them without consulting the diagrams.
And regarding documenting M12 pins, then yes, but if you make one you have a template for all subsequent connectors.
I/we normally don't see the signal wire marked if the sensor cable wires are all landed beside each other in the panel. None are marked on most to all systems we have here or that I have seen in recent years elsewhere. For any panels we build in-house (not a lot) we would only mark the sensor cables and none of the actual wires. An exception may be where the signal wire is landed some distance away in the panel from the other wires in the same sensor cable. But normally they are kept together where possible. For industry standard DC M12 sensor cables it is usually pretty obvious to Electricians that the Brown is 24V, Blue is 0V, Black is N/O signal and White is N/C signal (if used). But yes, I have also seen systems where not only the signal wire is marked, but all wires are marked. It does no harm but costs a little in time, money and effort. I'm sure for professional panel builders there may often be customer specifications where each wire must be designated and marked, especially in higher level or Government facilities. Maybe petrochemical, pharmaceutical, nuclear, I'd imagine?
Our cables are marked with two designations -
1st Designation > =Schematic Page-Device Designation
Example: =100-WS1/2
100 = Schematic Page
WS1/2 = Device Designation
2nd Designation > (+Terminal Group-Terminal Section)
Example: (+1C-XL4)
+1C = Terminal Group
XL4 = Terminal Section
The schematics are of course important for sensor designation. It's good practice to illustrate both the pin numbers of the M12 plug socket arrangement and the wire colours. A Cable Designation list should also be drawn up to cross reference each cable in the system. A panel layout schematic can also guide you to where the terminal designation physically is in the panel.
This is a sample from one of our latest systems from a very reputable global OEM who would be adhering the the very best in wiring standards...
(Note: the photos are just samples and not intended to represent the sensor cable in the schematic)
Note how even multi-core cable wires are not individually marked. The colours are illustrated in the schematic so it's not really essential. If it was done though, I wouldn't complain.
Regards,
George
What are people using to put their manufacturing tag on industrial control panels that they build for other people? Do you you an adhesive label...
1,733
Hi, Just wondering what everyone uses for terminal strip labels? We have an old Roland DXY-1150 plotter with ACS (Murrplastik) software that...
2,152
I'm using Beckhoff EL-series I/O terminals but this question also pertains to the similar product from Wago. One of these brands is also private...
1,661
All, What type of naming convention do you use for labeling the locations of each area in your cabinet? Is it arbitrary or based off of where...
1,136
All, Quick question. I have a scheme for how I label my own wiring, but do you have a method you follow for labeling someone else's already...
2,457
