Logix5572 program upload problem
ect_09
Jun 2013
hostle
19
Hi All,
I need your help that i want to upload the program from Logix5572. Communication is OK through rslinx over ethernet. but when i try to upload program from the CPU it shows following message as attached 1.jpg and go to offline.
when i try to go online then the message appeared as attached 2.jpg.
what should i do to upload program from logix5572. i am using rslogix5000 v19.01.
Thanks....!
Try to create an empty project with the same controller type. Save it, then try to go online. Select an option to upload from the PLC.
Ethernet or USB? if you can see the CPU in RSLinx on the Ethernet try uploading via USB and see if the same happens
Do you have a printer? or a walmart ? its a USB A to B cable and a lot of printers use them... or if you have a walmart close by they should have one
If not, then double check your Ethernet settings and make sure your on the same subnet, I have had processors show up in RSLinx that were not in the building
This is most likely a problem between RSLogix 5000 and RSLinx, rather than a network or driver problem. That "RSLinx has been taken offline" and "could not communicate with RSLinx" error message suggests it.
As this is RSLogix 5000 v19, it's a few years old. I would re-install RSLinx 2.59 if you can get a copy, since that's the most stable pre-3.0 (which was introduced with Studio 5000 v21) release of RSLinx Classic.
(Edit; I double-checked and verified that the 1756-L72 was first released with v19 firmware).
You need RSLogix 5000 v19 because you have a controller with v19 firmware in it. The major revision of RSLogix 5000 (after v21, it's called "Studio 5000 Logix Designer") must match the major revision of the controller.
That's why you can install multiple versions of RSLogix/Studio 5000 on the same computer.
I recommended RSLinx Classic 2.59.02 because it was the last revision of the pre-v3 RSLinx Classic architecture.
I don't know if this will fix your problem or not, but RSLinx Classic (lite) is free to download, and it can't hurt to have a stable version of the software on your computer.
118
Recently we had a process trip on compressors. When investigating I found three of six redundant pairs with DISQ status. Note these systems are in...
1,691
Does a Allen Bradley 1756-L72 ControlLogix5572 controller have a battery?
10,610
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
86
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
63
