Lost output data file on download
cirtcele
Apr 2007
Illinois
64
Got a problem with the loss of output data file configuration for analog input modules on download for a A-B SLC 500. Its happened to me a couple times, i saved the program while online then went offline made some changes that had nothing to do with the analog modules. After downloading the edited program i had to reactivate the analog input modules output data files. This has happened on two seperate plc's. I didn't clear the processor memory before downloading not sure if thats what caused the problem.
Usually analog modules configuration data is written to an integer and then on first scan copied to the modules configuration word ( an output data file).
Integers are retentive and should not lose there data.
Post your program and tell us which modules lost there configuration and maybe someone can spot something.
hi everyone, I have a problem, it seems that in somewhere on the programming the reference tends to lost mabye one time at day. I write this...
93
Well, not sure what else we can do with this one at the moment. Will chat with Rockwell in the morning but am not expecting much. Guess I'm...
1,146
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,071
I'm working with a 1734-AENT PointIO module (manual) connected to a 1769-L30ER controller over fiber ethernet. The 1734 PointIO module has some...
1,066
Hello, My laptop was rebooted lost 500 & 5000 tried to re-install but need to activate, need help badly, Thanks
783
