The application is consisting of two gigantic masterdrive MC:s that is supposed to be syncronized to each other. One of the drives is getting the setpoint value via profibus interface (from a Simatic S7-400). This drive is having a Virtual master running which is sending the setpoint out on Simolink. Both drives is then receiving this setpoint from the Simolink. When both drives is syncronized they run perfectly without any problems at all.
BUT.. when the power is cut off via the mainswitch for the hole machine they go crazy, i.e. they lose their syncronization. When you try to start the machine after this, the slave drive (the one without Virtual master) will enter fault state F011 (overcurrent) maybe because of to big dynamic requrements? If we now set the speedregulation in the drive to be very slow (Kp=1 Ti=1000 ms , normally Kp=20 Ti=100 ms) it is possible for the drive to syncronize once again and then it gets running again.
How to solve the problem?
1. Is it possible to set some bit in the masterdrive that is telling the drive "now you are perfectly syncronized" without doing any movement?
2. Change some parameter so the drive make nice, smooth movements to syncronize? I have tried to change the acceleration and speed parameter of the "correction movements" block but it didn't help.
Any ideas, suggestions, experiences, hints are highly appreciated.
Kindly regards
Wille
Kindly regards
Wille
