Maximum Display Size of FT SE HMI
minaykha
Apr 2009
singapore
96
Dear All,
IS there anybody run Factory Talk SE client file on 24" LCD display before ? Is it display look good ?
My client asked me to provide the work station 24" LCD monitor as HMI unit. I am not very sure that it is suitable or not ?
Thank you.
There is no realistic maximum size. It is just a program running on a PC (well, several dozen programs), so the display can be whatever your PC/monitor can handle.
When working on large displays, I strongly suggest having an even larger display for your development enviornment. Scrolling is FTStudio is an exercise in frustration.
Wether it "looks good", or not. As you put it, will depend on the screen resolution not its physical size.
True that, 640 x 480 VGA will look crappy on a 60" display :)
Always try to use the maximum resolution of the display, and develop in the same resolution; FTView can't scale things well.
I did one FTView SE display using an 50 inch monitor. Using its native resolution. It looked great.
I've seen things running on 60" TVs overhead in rooms before and looks fine.
Resolution is what matters - not screensize so much.
What is a reference for the maximum jitter on the cpu of a controller for motion control? We have done some tests on an IPC with Codesys...
1,033
Hi PLCs.net! I was curious: How many axis can a B&R APC910 control? Is there a hard limit like certain AB controllers? I'm new to B&R, so would...
371
Hi all, Quick question about maximum RIO for a PLC5. I'm looking to add some a RIO drop that emulates 6 racks to my existing PLC5 system (It is...
1,978
We are in the process of upgrading our PLC5 machines from Devicenet blocks with analog (current) inputs. We are looking at going to IO Link, due...
2,577
Hello everyone, What's the difference between nominal sensing distance and maximum sensing distance in a diffuse photoelectric sensor ? in...
1,124
