Hi all. Trying calibrate a metler toledo unit, however when doing the span calibration no change is happening when measuring the 4-20ma. Trier a spare unit but the same problem.
I am able change the zero figure to 4ma, the low and high cutoff values but doing the span for the 20ma figure with the weights on no change is happening i.e in this case the value is stuck at 4ma. Could a faulty load cell be preventing the value changing? There is four connected to the unit all wired together into the terminals shared.
Thanks in advance
Thanks in advance
