micrologix 1100 analog input
is the analog input on micrologix 1100 only for 0-10V ??
The embedded analog input is, with a 10bit resolution ( 0-1023 counts)
Just put a resistor across the input terminals 250 ohms gives you 1 to 5 volts, 500 ohms gives you 2 to 10 volts.
You can add an analog input module also. To accept the 4 to 20ma and give you better resolution.
I just have a quick question on this processor. I am making a project with 18 analog inputs so I bought 4 - 1762-IF4 expansion cards and the plc...
1,537
Micrologix L16BWA It has two built in analog input ports. How do I change the input type and range? current/voltage, 0-5v, 0-10v, 4-20ma, etc...
3,907
I bought a MicroLogix 1100 Series B processor off of eBay a couple of years ago ... the digital inputs and outputs worked fine ... I never tried...
2,310
Hi! I'm kind of new to PLCs and I'm learning basics on MicroLogix 1100 with RSLogix Micro software. I want to write simple program to create...
5,957
I am trying to put together a program for a control valve and scale combination. I will be using a ML1100 PLC, a 1762-IF4, and a 1762-OF4. I will...
9,653
