Ron Beaufort
here's what I'm finding that looks "fishy" ... specifically, it seems to have faulted INSTANTLY (on the First Pass) - and it looks like the Status File has been set to Always Load from a Memory Module - and the memory module doesn't seem to actually be present ...
first guess ... someone inadvertently changed the program to require a memory module - and didn't provide the module ... but I'm not betting more than pocket change on this one ... but it sure does look "fishy" from where I'm sitting ...
EDIT: as long as it is SAFE to do so - you might try changing bit S:1/11 (shown as a ONE below) to a ZERO and see if the thing will start up OK ...
