irondesk40
looking at possibly having to use the micrologix 1762-IQ32T input module as well as a 1762-OB32T module. I looked them up on the AB site and see that they use a 40 pin female connector that uses crimp pins. Have never used these. What size wire could you put in the crimp pins. I would assume it is pretty small. The documentation shows that you crimp the connector around the wire and then solder the wire. Is it possible to order a cable with the connector to plug into the input card already wired into the connector and then you could just strip the cable back and terminate each wire where it needed to go.
