Mitsubishi FX3U and File Registers
oncewaslost
Nov 2007
IL
Can someone help me understand what is the benefit of using file registers as opposed to regular latched data registers. We mostly use the FX3U. The manual would lead me to believe that it assures that the data stays with the program. In doing some testing, I can see no difference. It appears to me that to keep the data with the program, you still have to check the box in GX developer when reading out. The same as standard registers.
I have used file registers in an old FX when we needed more data storage. Sacrifice step memory to create more data registers. The FX3U has an enormous amount of regular latched data registers anyway.
They are mostly used for a data base of registers that will not be changed. Ie, resetting the program back to an initial good state by a block move BMOV.
We do exactly that with regular latched data registers. So what would be the advantage of using file registers?
Thanks.
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
180
Hello everyone; I have Mitsubishi PLC FX3U 32M in hydropower plant governor, an error message popped up when a technician was working on an...
394
hmi keeps saying "insufficient sensor failed" after the machine runs for 60 seconds. its a fx3u-48m PLC. The plc is not giving any errors or...
2,291
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,955
Hi All, I am looking to install a Red Lion CR3000 HMI and connect it to a Mitsubishi FX3u 64M PLC via Serial. I cannot find confirmation on...
2,869
