Modbus rtu setup m221 and modscan64
hadwll
Oct 2017
UK
21
I am trying to setup comms between my computers rs232 port and a schneider M221 PLC. (ultimatly with the intention of setting up PLC -> HMI Comms...)
I am using a straight through rs232 female to female cable.
I have configured the baud rate, parity, data bits and stop bits on the PLC, the serial port in windows device manager and the modscan application. Made sure to select RS232.
At the point were I click connect it is not able to connect to the PLC giving "connection failed dialog"
What else should I be looking at?
should I be using a straight through cable?
Which M221 model and which cable?
M221 have RS232 but you need first configure it and it is screw connection or RJ45 depending hardware.
Can you provide some clarification on the cable used and the connections?
It seems the M221 PLC uses an RJ-45 jack for serial communications (either RS485 or RS232, software configured):
https://media.distributordatasoluti...bbe12ae5adf011e7952b3019b1bd5d.pdf#G34.657572
If you have a female to female RS232 cable, does this have a DB9 connector on either end? Are you using a RJ-45 to DB9 adapter? Note that Schneider has two different RJ-45 to DB9 adapters, one for DTE and the other for DCE.
A PC is a DTE devices, so if you're using the DTE adapter (TCSMCN3M4F3C2), you would use a straight through cable. But if you're using the DCE adapter (TCSMCN3M4M3S2), you would use a null modem cable. Here are additional details on DTE vs DCE and null modem cables:
https://www.decisivetactics.com/sup...r-null-modem-vs-straight-through-serial-cable
It's a TM221ME16R cpu.
I'm using a cable I hacked together. Thanks for the schneider part numbers. I've ordered the (TCSMCN3M4M3S2) it will be here tomorrow I'll try and report back
Thanks for the reply, let me get the right cables and report back
Cheers.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
65
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
302
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
302
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
138
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
610
